Thanks ajmboy that was my thought but tried hot wire to by pass ignition not that did find sticker telling me was not actually Honda recon but fourtrax rancher350 fm 2003 have just ordered new starter relay and amp meter
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
    • By Ethan7387
    • By Eisaks777
    • By Snick
      ^PINOUT:
            5   6
            2   4
           1    3
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
