    • By geezer99
      I have an Axis 500 made by Hisun.  I uses a solid rear gearbox with no differential action.
      I would like to convert this to a true differential with locking ability.  I've searched all over trying to find a source with no luck.
      Has anyone done this before, or know of a source?
      Thanks,  Tom
    • By qcm413
      Hi,
      Thanks for a newbie on this site !
      i have grinding noise in my front differential. the front right wheel is turning and the left is try to turn but no movement and make sound like a gear broken. somebody have any idea ? not enough oil in diff ?
      thank
      Just checking to see which differential oil everyone is using: Valvoline, Lucas, Honda,Yamaha etc.
    • By anthonyd256
      I have a 99 Yamaha bear tracker and I have converted the front brakes from drum to disc fairly easy but I cant figure out how to convert the rear with out hacking apart the rear arm. tried to use parts from a wolverine since the rear arms look similar but the caliper mount didn't line up on the bear tracker axle. Can anyone give me any clues or has anyone successfully converted the bear tracker rear brakes. I would even purchase a conversion kit if there is one. Any help on this would be greatly appreciated.
    • By McG75
