By kawasig
By BuckBilly
By Randomnumber73
I'm working on my uncles grizzly and it sparks once on initial cranking then no more after that. If I let off the start button then press the start button again it will spark once then stop sparking. I was wondering if anyone seen this issue before. Also I've never used forums before so sorry if this question is in the wrong location.
By KSIM
View File 2018 CF-MOTO Z-Force CF1000US-2 service manual
CF-MOTO Z-Force (CF1000US-2) (2018) service manual
Submitter KSIM Submitted 03/19/2025 Category Other Brands UTV
By TimothyLindblom
Hey all, I just picked up this Massimo UTV for $500. Got it home and replaced the starter solenoid which successfully got power to the starter. Starter spun but engine didn't turn over although the engine is not locked up. I thought it was a bad starter. Got a new starter put on today and it does the same thing. Pulled the clutch cover and saw the engine is trying to turn over but something is slipping and not letting it turn over. I figured it must be the gear on the engine that the starter turns. Where can I get that and can it be replaced without pulling the motor? And am I correct that that's the issue?
Thanks!
Short video attached below
