I would think the same, maybe you are losing spark under load? Does it start to bog down after its running for a while or pretty much random? Have you change the plug, checked your wiring? Maybe its a bad ignition coil?
I'd  check  for loose or corroded  connectors  in the ignition circuits  first since it started  after bouncing  around .  Check the  voltage   from  rectifier  to  battery under  idle  and revved up. If  you  can  borrow  a compatible CDI  box,  you  could try  swapping it  out.  There  is the service manual  for the  1998 YMF250  in the  downloads section of the forum .  It will  have all  the  resistance readings  for  the  ignition  components should you  need to  check  the  stator,  pickup  coil and ignition coils. Most  likely  the  readings would all be the same  for  the  2001.  Very little  changes  from  year to  year for the  same  series  motors.
Check  components  cold  and  warmed up. Sometimes   they  break  down   when  hot   but are fine  cold.  One tool  that  isn't expensive    but is  often  overlooked  when  suspecting  spark  loss  under  load  is  an  inline  spark  checker to see  if   the  plug  is  firing  properly  under  load.
Here  is an example of the  spark  checker https://www.harborfreight.com/90-in-line-spark-checker-69023.html
Well it's random. Sometime it starts cold and it's fine. Still has a little hiccup when I crack the throttle from idle, even with choke 1/2 out.  When it started running real bad ( as in wouldn't pull itself) it did it cold and hot.  I tore carb down and cleaned and it still did it.
Man this is great advice.  I'll pick up a spark tester on the way home. Now that I'm back at the shop ( and not in a field) I'll pull the plastic off and check all the connectors. I do believe I have a bare wire showing at one connector where the insulation has pulled back at the plastic.  I don't  think it's shorting but I'll double check.  The bouncing around and randomness of the sputtering is why I believe it's electrical as well. I was reading about some "parking break" governor or something. What exactly happens when the parking break is engaged? Is it possible to disengage it completely to ensure its not a faulty switch? Also I'll keep this thread up to date until I find the solution, for any future people to read.
Any chance the fuel tank has junk in it ? Maybe remove the petcock (gastank valve) and check the screen and inside to check for junk and that it’s not starving the carburetor for fuel?
Esp since you said when you start moving the bike around it gets cranky.
Sorry for the long update, since I posted this I blew the transmission out of my race bike, which ment tearing down the 450, while trying to rebuild my camper, and getting ready for a hard enduro competition on the one weekend that wasn't a race weekend. I have yet to mess with the bear tracker, however I did take it to the last event and it basically stopped running. Stumble is so bad it barely has power to pull itself, choke in, 1/2, out doesn't matter it wouldn't run.   So I'm hoping to get around to tearing it down in the next week or so, I will still update this page when I figure out what's up.
Well I finally found some time and I'm back at it again.  I went back to the stock carb, ditching the zoom zoom it had on it. ( stock carb had a stripped out pilot jet) but that's been removed and entire rebuild kit had been done back to factory settings. I put it on and it ran fine, for about 10 mins. My wife then rode it around the yard and said it did fine. I got home, cranked it up and it started fine, idles great, but as soon as you get on the throttle it wants to die. Seems to be mid throttle.  Pulled all the plastic and don't see any shorts, disconnected the brake safety switch, no change. It already has a new intake boot, but sprayed around all the carbs and boots with starter fluid and no idle change. has a clean plug in it as well.
Have you had a chance to try  another stock  carb on it ?. It  still sounds like a  lean burn problem  off idle.I'd look again  for a clogged  passage or a  small  missed drilled  hole  in one of the jet tubes .  Make  sure  float  level  is right  and  no  crud is coming from the tank to possibly restrict fuel  flow ..  Is the diaphragm  good /new and working as it should?  Is the  spark  plug  new  or known  good ? Some plugs  can be fine at  idle  but  under the higher pressures  when  throttle  is opened can  cut out  or  be  intermittent .
I tried the zoom carb, and it wasn't right. Rebuilt stock carb was good " for a few mins". Im going to stick a new plug in it again. I tore the carb apart again yesterday, triple checked and all passages are clear. Float is set at 13mm. No fuel filter on tank right now, good flow from tank to carb. Throttle slide boot had no visible holes, or rips, same with the side rubber enrichment thing. what are the symptoms of a bad CDI?
I've  never  had  to deal  with a failing  CDI,  but it  is possible  for  one to  become weak and intermittent  as it  heats  up . You seem  to  have pretty much eliminated  everything else .  Hopefully  you  can  borrow  a good  one to  try  before  putting out  the bucks for a new  one .  Friends of mine who  had  CDI problems  had them  fail  completely  when they went.  Like  anything electronic though, a component  can  get  weak  or out of spec  and  cause problems.
Great updates and advice in this topic! I’m enjoying following it. If it now runs better with the stock carb but on higher throttle bogs down, could it be jetted incorrectly?
So here's the challenge. I have 7 days to make this ( never ran right) ATV and get it running, so that I can't take it to Colorado on vacation next week.  I also have to work 6 of those days.... So got some work ahead of me.  My next step is to pull the stock carb, and rip all the jets out of it, swap them into the ( new) zoom carb.  If it still doesn't run right, I should know for sure that it's not a diaphragm issue, or carb issue and more then likely electrical. We will see what happens.
Update:   No solution was found... not the greatest outcome but I wanted to update this thread.  I sold the Bear tracker as it was.   I will try to update the original post to state that to save people looking for the same problem in the future time.
  • 6 years later...
Same exact issues with 02 yamaha big bear.   Replaced with new carb. Same issue, bogging down when throttled past mid range. Bought another new carb, replaced again. Same issue. Good gas, jets all correct, screens clean, fuel lines clean, good gas, new battery, new plug, filters etc…Not sure about the CDI, but how about replacing the stator?Thoughts?
A new thread makes it easier to follow....
Does it backfire ? Is it out of the carb or the exhaust ?
Are you certain it's the mid range that's causing it, or could it perhaps be that it's when the load starts coming onto the engine that it starts to misfire ? In which case it's more likely to be a coil or lead, cap or sparkplug. The way to check if it's throttle position, or engine load, is to go up and then down a slope/hill.
Start a new thread though.. Otherwise it's too easy to confuse bikes or owners or problems..
Edited by Mech
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Frank Angerano
