Hey JD, welcome to Quadcrazy. I’m sure you double checked your work and I’m sure it all looks right.   But could it be possbale that your are 180 deg out on the timing ? The marks are funny and there are a few different marks on the flywheel. It’s super important to have the proper timing mark and not just a line on the flywheel.  It should be a “T” on the flywheel as a TDC reference point.
Have you looked at the piston and valves to check for damage ? Maybe a blown or jumped chain caused damage.
Have you tried staring fluid and sure the  carb is clean and delivering fuel ?
Reason im asking is it’s pretty simple if what you say is accurate by having spark, fuel and compression there should be no issues as far as starting.  (Other then timing)
Now having said all that the next step would be the stator and pulse aka trigger coil to make sure it’s sending  spark at the right time to the spark plug.
You know what.. I think it is 180 out of time lol. I was thinking I was checking it on compression stroke but I bet it was on the power stroke bc now that you say something, I did have to turn it a little too far after it blew out air.. And I didn't check to make sure I was at tdc when I put it in time. But if the mark is right on the crank the piston is up.. Hmm. Thevalves weren't in the right position then.. I had it set right before I started taking it apart but I was turning it without thinking during their process. Thanks I'll check it out.
I’ve never used a timing light on a quad. Once the marks are set the timing should be set and locked. Unless there is a slacked chain maybe but that’s about it. The tdc on the compression stroke and the “T” mark on the flywheel are all good then maybe take a look at the trigger/pulse coil. Maybe somethings going on there. I also used a spark tester on the bike to see how the spark fires during engine rotation.  But possibly the trigger coil having an issue.
Was the head taken off the bike ? What’s the history from the person you got is from.
The “it just quit on him” doesn’t sound right. Maybe he took it apart?
Does it look like the head was taken off? New gaskets or any fresh marks like was taken apart other then the chain tensioner ?
No it hasn't been taken apart. He did nothing to it. He told me it was getting spark and wouldn't hit off starting fluid.  He said he was just riding across a field and it died on him. That does sound like timing issue to me. I verified all the things he said and then I checked timing and it was off twoteeth and the tensioner was no good so I ordered them. Installed then And it's doing sane thing. I'm gonna find a way to see if it's sparking on time.
  • 9 months later...
    • By Tim Keiper
    • By Tinkeringreg
    • By Mhatayas
