I have 8" Red Mud Caps for sale- these are brand new and the same ones the pro's use. These will fit ITP,Douglas and HiPer 8" beadlock wheels only.
$10.00 shipped for one set (two caps)
any questions just let me know
I do take paypal or money order
    • By JMSwed
      Hi EVERYONE
      New member here
    • By qcm413
      Hi,
      thank in advance
    • By marcosphoto
