I took my '99 King Quad 300 out this weekend for a shakedown run.  It ran well, except I found that it was a little hard to start.  I've found that for the first, early morning starts, sometimes it fires right up and other times it takes some cranking and then sputters to life (choking it and using the same starting methods each time).  During the day, after running it for a few hours, shutting it down for a couple of hours, and then coming back to it, it was a little bit of a struggle to start it.  Again, it was more of a stumble and sputter to life.  Once it was running, it ran fine though.  One odd thing I did notice that sometimes the cranking sounds a little labored and other times it spins over normally.  Almost like there's some sort of resistance that isn't there sometimes.  Any ideas on what intermittent hard starts might be?  The quad has about 5,500 miles on it.  Do you think a valve adjustment might help?
Thanks.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Frank Angerano
    • By Tinkeringreg
    • By beast6228
      However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it.  If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
