Hi,
I'm having some issues with the carb on my '99 King Quad 300.  It idles, runs and revs smooth and without hesitation when the choke is on, but when I take the choke off, it still idles fine, but no longer revs smoothly and hesitates and hiccups.  I've adjusted the pilot screw and it helped some, but it's still not right.  Any suggestions?
Thanks.
Sounds like a fuel delivery problem. Float may be stuck or the needle inside the bowl is not free slowing the fuel into the engine.I would take the carb apart give it a good cleaning and make sure all the orafaces are clear as well as check fuel flow from the valve on the gas tank. Sometimes this valve can have an obstruction inside slowing fuel delivery.
Good luck.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Dumass
    • By Trent Finnessey
    • By neilroy87
