You can use other muffler if you can do some welding or get it attached. However depending on the exhaust, you may need to jet the carb. What exactly are you looking to do? Put something on like an aftermarket pipe or back to stock?
    • By motox88
      Anyone have bad experience with these clutch kits?  Looking to get one for an 80s quad that I have.
    • By p5200
    • By jatho
    • By anthonyd256
      I have a 99 Yamaha bear tracker and I have converted the front brakes from drum to disc fairly easy but I cant figure out how to convert the rear with out hacking apart the rear arm. tried to use parts from a wolverine since the rear arms look similar but the caliper mount didn't line up on the bear tracker axle. Can anyone give me any clues or has anyone successfully converted the bear tracker rear brakes. I would even purchase a conversion kit if there is one. Any help on this would be greatly appreciated.
    • By picriver
      new ignition switch
      four wires - green, red black, black with white line
      atv four wires - pink, pink with white line, black, red
      which is attached to which, please and thank you?
