Any every replace or work on the parking pawl. Believe mine either got broke or worn out not working any more .
I've already took the linkage loose at the loose at rear differential and moved it by hand and can feel the pawl lever cam working but it does not engage the parking pawl. And yes it rolls freely while in park with no noise from differential like something is broke. Vinson runs just fine but no Park
Finally took it apart last week, the parking pawl was broke, I have the factory service manuals both the pdf and printed, the pictures in the manuals are really not that informative in either. The parts are on order will try to post some pictures later. The parking pawl looks to be made of some kind of cast pot metal, fortunately it just broke in two pieces and fell down into the parking pawl housing away from the input shaft
    • By DaleJAM
    • By Coyote251
    • By motox88
    • By geezer99
      I have an Axis 500 made by Hisun.  I uses a solid rear gearbox with no differential action.
      I would like to convert this to a true differential with locking ability.  I've searched all over trying to find a source with no luck.
      Has anyone done this before, or know of a source?
      Thanks,  Tom
    • By qcm413
      Hi,
      Thanks for a newbie on this site !
      i have grinding noise in my front differential. the front right wheel is turning and the left is try to turn but no movement and make sound like a gear broken. somebody have any idea ? not enough oil in diff ?
      thank
