I have a 2005 suzuki vinson 500 LTF500F. I can not get it to start and stay running. cleaned carb, rebuilt carb, cleaned and blew through all ports with air gun. Only way to get it to half way start and run is to put hand over hole on air box and then it starts and will run for a couple seconds until it sucks the intake tube SHUT! You then can hear it sounding like a air leak after it stall out until the intake is back to normal. Anybody have any ideas?
check for an  air leak  between the  carb and the  engine ..   Double  check  the  carb  again..  Float height ? ..  a  passage or  jet  blocked  that  you  missed ? ... Sounds to  me  it  is not  getting  gas  or  it  is extremely  lean   unless  you  manually  choke  it  by  blocking the  intake. Try  turning  the  idle  air  screw  in  until  it  just seats  and then  back  out  about  1  1/2 to  2  turns initially. Does  it  run  if  you  only  half to  3/4  block   the  intake?  Completely  blocked it  can  only  run  momentarily   until  it  no longer is  getting  any  air through the  carb.
Thanks Dave for replying to my post start with, but yes that's the only way it will run by blocking the intake tube until it starts and then very slowly pull your hand back just until the intake tube starts to not collapse anything. I've checked float height before I rebuilt it and then matched it to that, so it should be close. I'm really leaning tore having a vacuum leak but not sure where at this point. I will mess with the idle air screw some this evening and get back to you
I'd double  check  all  the  jets and passages too.  I  did  a search  on  your  carb  and see  there  is what appears to  be  a stiff  rubber  part  between the  block  and  carb.  It  could be  cracked..   I  saw in another  forum  that the  floats actually  have two  tabs to  adjust them . One  sets the float  height (  I  believe it  said 13  mm),  and the  other limits the  amount it  can  drop controlling  how  fast  the fuel  can  enter the  bowl .. Since the  high  speed  juts  are  fed  from   the bottom  of the  flaot  bowl  ,choking  the  carb the  way  you  do  could  put   vacuum  pressure into the  bowl  and  pulling  fuel  up  from  an  inadequately  filled one.  I  found a  video  on rebuilding  the  carb.   I  don't know  it  it  will  help  you, but  I'm  posting the  link.  In  similar  carbs  I've  worked on,  I  have  found some  very  small  holes  in the    long  jet   that     can  be  blocked  and  not easily  noticed.   Make  sure  you  remove the  jests  and check  closely   for missed  blockages . Welders  "tip  cleaners"   have  a  variety  of wire  sizes  that  fit  for  cleaning pretty  much every  jet.
Thanks for the video!! I tried looking for a video when I was cleaning mine and couldn't find one. This evening I'll take it all back apart and check everything Again and try it. I'll keep you post. I really appreciate you taking the time to help me out
Sent from my SM-G950U using Tapatalk
One thing about being  retired ..   The  pay  may not be so  good  but  I  have  lots of time  to  play  on the  pc and with  my  toys.
Growing up   on  a  hobby  farm,  then  living in the  north  and working as a  millwright, messing with  mechanical  and electrical /  electronic things  all  my  life  I've  learned  a fair  bit of  how  things work..  I  can  very  seldom  answer  specific questions  in   the  forum ,  but  I   can  often   offer  clues on where to  look.  Being  able  to  search   things  out on the  net  is  a huge  bonus in  looking for solutions .
sorry for no response. I decided to just take the carb to work and due another good cleaning and use shop air to get in all the hole. will put it on this evening and give a up date
Ok..... cleaned the carb good and adjusted the air/fuel screw and tried it. It idles pretty good but I did find some rust in the tank from the fuel cap, gonna drain the tank and wash it out and put new gas in it and try to see what happens. So , for now it's possibly fixed . Didn't let it run long so it wouldn't suck the rust in the carb. Will know for sure tomorrow
Sorry took so long, but great news! After doing everything that I said I did I finally today for to try it out and it idles and drives great! Can't say enough how important it is to make sure the carb is CLEAN lol. Thanks again
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Tinkeringreg
    • By Mhatayas
