    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
    • By Vlaco
      I want to replace the factory headlights with LED bulbs. Any idea a good one to get?
    • By Tuzz
    • By JohnnyB
      Greetings,
      Have a 88 LT80 that been sitting for a couple years. Bought a new piston, cylinder and head. Installed these, rolled it over and it quickly locks up.  Took carb apart. It was full of what appears to be 2 cycle oil. Cleaned it, but keeps locking up and 2 cycle oil continues to seap from exhaust port.  When i installed new cylinder, I noticed crankcase was full of oil.  I'm now wondering if that oil is what's getting sucked up into cylinder.  Should there be no oil in crankcase?  If that the case, how is crank and rod lubricated?  Sorry, never worked on a 2 stroke. Thanks!
    • By Am2007
      Hi everyone,
      owner manual
      service manual
      engine manual
