Thank you, you're the only person who has replied on any of the forums I have joined just to get this simple question answered.  I can't find the vin number though.  I've researched where it is supposed to be but it's not anywhere I've looked.  Dead end I guess.  Thanks for trying anyway though!
According to a  post in another  site : Try looking on the upper frame tube on the rear left side under the wheel well.
As  Frank  says .. There's  one  somewhere  on the  frame.
Try  looking for a    number on the  motor  too. It  might be  possible to   id  it  from that .
As  far  as  oil  is concerned,  you  likely  can't  go  wrong  with a 10w40 (MA  in the  specifications)  suitable  for motorcycles in the  engine  and  a  75-90 hypoid oil  in the differentials. According to  other forums on engine  oils   avoid the  "Energy  conserving"  oils. They  have  friction reducing additives  that  can  screw up  wet clutches.
You do have to be careful to use the right oil. It has a wet clutch and you have to use the right oil.
The one picture is not enough to identify the machine. A front and rear picture could help. It looks like a 2001-2003 machine
possibly a 375cc.
    • By bigd764
    • By Charlesbrown
    • By opnea
    • By DayBreakJim
      20230725_171507.mp4
    • By psychodad
      Have a carb off an '07 Big Bear 400 that sat a couple of years, probably more.  Friend asked me to clean it, which I did, soaking the jets and spraying out all of the ports with carb cleaner as best I could.  Replaced o-rings, needle valve & seat, tweeked float level.  Bike starts and idles well but doesn't want to pick up above 1/4 throttle.  That would appear to be in the slide needle range.  Main jet is clean, needle is clean and straight, diaphragm good.  It seems I saw (in a diagram) a port that comes into the slide needle area from the side.  This would be in the carb body between the main jet and the throat of the carb.  I would like to soak the carb in Gunk Carb Cleaner, the gallon paint can with a little basket.  Curious what Mikuni uses for bearings and seals in the throttle shaft.  I'm guessing HDPE or Delrin, or maybe brass; not sure what effect Gunk would have on the polymers.  Has anyone actually soaked a carb in Gunk??  First hand knowledge, please, and what effect, if any, on the carb.  Pulling the throttle shaft out would be a last resort.  Getting the butterfly screws out and staked back in would seem to be a nightmare.
      Jim
