Hi All,
I have an 87 lt4wd quadrunner 250 and the choke cable is not there, speedo is frozen, left brake handle is frozen, right brake handle and reservoir is missing but runs good and all gearing works. I'm starting with the choke install. I have the manual downloaded and printed (472pgs) It is hard to see. Any help is welcome, the first thing I did was oil and filter with front diff oil change coming up soon.
RUSTY
  • Like 3
I have a twin of this that I use for parts, that will work on a 1988 LT-F250  2WD . Any thing that is unique to the 4WD may be available. ie choke cable, carb etc. I have the from brake master cylinder and handle complete front driveline, short of the rt ft inboard drive axle, I will keep the engine top half but the complete gear case and engine lower unit will become available. As I said though anything that ill work on my 2 wheel I plan on keeping.
  Let me know if any of this is feasible for you.
Hope it works out for you.
Tim.
    • By Mhatayas
    • By TimothyLindblom
      Hi everyone, I’m new here and new to 4 wheelers. Just got a Yamaha bear tracker 250 and joined here to see if I could get some help.
      The motor runs and it drives if it up on jackstands but if you get on and try to ride it, it starts to drive but then quits after a foot or two and dies out and won’t drive. The guy I got it from said he was running and using it shifting through all the gears great and he started it up the next day and it started this.
      He told me he thought it was the U joint on the driveshaft. He said it was probably worn and needed to be replaced.
      I just finished pulling the swing arm and rear end assembly to check out the U joint and there’s no play in it. It’s tight and not nearly enough play to be loose enough to not catch and go.
      Any ideas on what it could actually be?
      Timothy
    • By Need-help-with-quads
      So my moto 4 is smoking white smoke and when I go to first gear and get about half throttle there’s no power and it sounds like it’s bogging
