I jsut picked up a 1999 polaris sportsman 335 4x4 and everything was working fine , next day i turned key on , everything came on as it should lights , awd, speedo, then i turned the high beam switch off and i lost everything on the bars! , if i wiggle the e-start cluster wire it turned back on ... then while it was on agen i tured the switch off agen and everything shut off and i cannot wiggle it to turn back on agen ! It will still start with pull start but no electrical all of a sudden... This is my first 4x4 quad help please help lol !!!
My guess is a  loose  or  corroded connection  or  a bad ground.   I would look  at the  ground connections  first , then the main  power  wire .  Tracing electrical  problems  are  always   "fun".
    • By Tim Keiper
    • By Gunny
      Hope you enjoy the video ....
    • By oxidized_black
    • By carkivey3
