Gibbs Quadski | TRANSLOGIC
By ATVNetwork
By gbanker
South of Tucson, AZ of RT 83. Rosemont OHV trails. 85°, sunny.
By mga
I get it, turn counterclockwise will decrease, turn clockwise will increase. My question is what exactly am i increasing or decreasing? Is it clutch pressure? In many videos i've seen it's always "turn counterclockwise" until you feel resistance then back off. Why is it always to decrease?
I'm just curious as to what exactly is going on when i turn that screw right or left. And, since there's no manual clutch to engage or disengage, what is going on inside?
Reason why i'm asking is while going down a hill in 1st gear, it appears to pops out of gear, but no neutral light, and if i stop, it's in 1st gear still. BUT, (always a but) if the engine is warmed up, it stays in 1st gear. The hill is too steep to use any other gear, so 1st with the brakes is the only way to go down.
By mattgoodwin
I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
By bighoss
i got my son new outlaw 50 a few weeks ago and we went rideing yesterday and while we were riding it died and it took me like 10 min to get started back and it died agen when we got close to truck so i pulled it back took the plug out it looked like it was drop in a bucket of gas took the air filter out and the ait box was full of gas also got home it started rite up today i started it it starter up but was blowing what look like water out of the exholst let it idel for a lil bit did not die but as soon as hit the gas and let off it will die what does that sound like i thnk i going to take it back to dealer and tell them to fix it as it is under warrenty but would like to know what it could be first
