    • By marcosphoto
    • By Coyote251
    • By huntindog
      TIA
    • By JohnnyB
      Greetings,
      Have a 88 LT80 that been sitting for a couple years. Bought a new piston, cylinder and head. Installed these, rolled it over and it quickly locks up.  Took carb apart. It was full of what appears to be 2 cycle oil. Cleaned it, but keeps locking up and 2 cycle oil continues to seap from exhaust port.  When i installed new cylinder, I noticed crankcase was full of oil.  I'm now wondering if that oil is what's getting sucked up into cylinder.  Should there be no oil in crankcase?  If that the case, how is crank and rod lubricated?  Sorry, never worked on a 2 stroke. Thanks!
    • By Sofaspud
