Hello guys. So I am having trouble navigating the forum here. I am looking for an exploded parts view or the service manual for a 2000-2004 Yamaha big bear 400 manual shift. Mine does NOT have a shift lever on front left fender . I took the rear end apart because it was stripped splines and now I can't remember where it all goes. (Seals, bearings, and torque specs. I have a new axle, used diff , need to install wheel bearings and brakes etc .  Really want to get this thing back together asap
i took a look to see if i could find a manual, but I don't have one on file. There are a couple of other members that have some manuals they may be able to share. There are a couple of yammys in this thread I believe:
QUICK tip, use the search box at the top right, the main menu links, and the links under your profile at the top right to navigate the site.
    • By Thumpinhard25
    • By Travis_Smith
    • By oxidized_black
