Have an Artic Cat 500 that will not electric start. I thought it was the starter as it sounded like it was just free spinning. (BTW it pull starts and runs fine except it is hard to pull half way out gets bound just keep trying till it starts) I replaced the starter with the results being the same. The gears u can see with the starter out will also spin freely with the finger. It's like it's not engaging the flywheel. Ideas?
On 11/28/2016 at 7:15 PM, Ajmboy said:
If you jump the starter, does it engage? Are you getting power to the starter?
Yes starter is turning but not turning the motor over, just a high pitch spinning noise.
On 11/28/2016 at 9:32 PM, wildthang said:
Sounds like you may need a starter clutch.
I'll check that out just got it home from the farm sounds like some tear down fun. Thx is there a way to tell by looking that it's bad?
Generally, what happens is one or more of the rollers in the one way clutch come loose. Once you tear it apart, it should be fairly obvious. Cheapest I found was $232.92 at Powersportsdiscount.com .
    • By carkivey3
    • By mmikesell
    • By EasyE
