I had quite the ride the other weekend. I rolled the quad then kind of submerged it. Needless to say I'm having some issues with it now. It idles fine, but when you lower the choke and give it some gas it pops out of the carbuerator and backfires from the exhaust. The carb is clean and the fuel is clean. I also changed the oil and the diff. I changed the spark plugs and checked the CDI box by switching it with a working one. Any other suggestions? Any and all suggestions would be appreciated!!
Guest CRAZYQuad
Sounds like the idle cotrol is messed up or air fuel mixture is off. Did anything get hit around the carb?
  • 10 years later...
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Trent Finnessey
    • By neilroy87
    • By Sportsman500guy
