Isn't that kinda normal? What happens is that by pushing the break pedal, you are relieving tension on the handlebar brake cable. You could adjust it, usually right where the cable goes into the brake handle. Although some ATVs have brake hydraulics, I'm not sure with the Vinson. Maybe someone else in the community would know more.
    • By mga
      on my left brake handle (for the rear brakes) there's two wires attached to it. What are these wires for? They can't be for the tail light, since it only has on filament  I tried to trace them, but i got lost in the harness. I checked wiring schematics, but didn't see anything like that.
      I'll post a pic later.
    • By geezer99
      I have an Axis 500 made by Hisun.  I uses a solid rear gearbox with no differential action.
      I would like to convert this to a true differential with locking ability.  I've searched all over trying to find a source with no luck.
      Has anyone done this before, or know of a source?
      Thanks,  Tom
    • By DGBear
      My front brakes started dragging and the lever travel was minimal. I bled them and topped off the fluid reservoir and they worked great for a while and now the problem has returned. I'm thinking that a piston may be sticking. Any thoughts on this problem?
    • By mattgoodwin
      I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
    • By anthonyd256
