My bayou was running. Turned it off. Went to start it again about 20 minutes later and nothing.... no electrical power. No lights, no neutral indicator light. battery good. Jumped starter and it turns over but doesn't start. I'm not sure what the problem could be. Maybe ci igniter or rectifier?
Edited by Ajmboy
Changed title
So if you connected a jumper pack and it cranks, your battery has issues. if it cranks and doesn't start, its either spark, air, or fuel. I would fix the no start/electric issue first by checking connections and ignition wiring to the key. After you fix that, dig into the no start by checking spark and fuel delivery.
    • By Thumpinhard25
    • By Tinkeringreg
    • By neilroy87
    • By beast6228
      However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it.  If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
