Im working on a old 1987 honda 125 4 wheeler in the school shop. It will start by getting pulled by another 4 wheeler but wont start with the pull start or Electric Start. When you pull start it it tries to start but when you try the electric start it just turns over but doesnt even act like it wants to start. The spark plug is dry and it shoots fuel out of the back(air filter side) of the carb. Weve had the carb off twice and it is complety clean. What are some things we can try?
How does it run once it is started? Could be a small vacuum leak. Or it could be the float is too high/low and it is letting too much fuel into the carb.
Sent from my XT1585 using Tapatalk
    • By Trent Finnessey
    • By Tinkeringreg
    • By Dumass
    • By Arizona
