I have 2002 450 foreman & the temp lite started to come on as I was riding; It would be intermittent at times. Changed the temp sensor, but lite still is intermittently on & off. Installed a switch for the fan so I could manually turn fan on & off as needed. The lite is still coming on & staying on . Any ideas on what else I could try? Thanks
    • By Trent Finnessey
    • By oxidized_black
      Engine
      Chassis
      Size
      Basics
      Features
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
    • By qcm413
      Hi,
      thank in advance
