Help! This hub has been soaking in liquid wrench for two days now. The hub puller in the picture has been on under tension with an impact wrench for 24 hours, removed and re-tightened at least twice in that time. I've tried smacking it from two sides simultaneously with ball peen hammers while under tension and also heating it until the liquid wrench began to smoke also while under tension and it's not budging. Anyone have any advice?
Sent from my SM-G920V using Tapatalk
Get the puller as tight as you dare, then chase the hub quickly with a torch. Heat will make it swell. Don't pu*** it, you need to get the hub as hot as possible as quickly as possible before the axle takes and expands. Like, cherry red. Not just burn oil. You need more then 300*F....
Sent from my One using Tapatalk
Edited by Cyberballz
    • By Joeguy
      I been working on this thing for like 2 months now and it will not run right, is very smokey, and has a pretty loud tap that i think is in the bottom end. Not sure how much the parts are but i will put the time into it if they are pretty cheap. Im not very experienced but going off how the plug looks and the oil on top of the piston i am getting a whole lot of oil coming in from somewhere, not sure if it can come from the valves or if the rings are just shot, my cheap scope cant really see the walls of the cylinder too well.
      20241009_123850.mp4
    • By heath
      i just bought a yamaha moto 4, i have sprayed 'start ya barstard' into the carb and on the spark plug and it doesnt even fire! although when i have the spark plug on the outside of the motor it shows spark, the engine also leaks oil from the starter,
    • By jannonballs
      What is this tube for?
    • By mattgoodwin
      I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
