2005 Arctic Cat LE 500cc. This last year the led readout has basically faded to where you can barely see it. This cat is always covered or inside, when not riding, so it's not due to sunlight fadeout I don't believe. Where does it get its' power from Is it from ECU under the seat?
I would pull the connector to the pod and clean it with electronic cleaner spray then reconnect it first. Its also called contact cleaner, you can get it at any auto parts store.
Mike
I have had the connector apart. The contacts were nice and clean, I should have checked voltage. Odd thing is, the fading is mostly from outside in, with the outside areas dark fading to light.
  • 6 months later...
I checked the fuse...okay. Disconnected battery overnight...still dim. Maybe the grounds are getting corroded? When I get back I will start with that. I'm in another country right now and won't be back until January, so be patient, I will be back on this subject then. Thanks, Larry
Whenever  you  have  dimmed lights or something like tail/ brake lights   working with headlamps off,  but not when  on, the first thing to  check  is the ground for the lights  or display.  The same applies  for   starters  not spinning over properly. Check the  ground cable  first  if  you  know   the battery  is  fully  charged. One trick many don't  know  is to   cover the  battery terminals with  grease or vaseline.  It  protects  them  from  corrosion from acid vapors from the  battery and from  general  corrosion  associated  from the  air  and road  grime/ salt  that  might find its way to the terminals. It's  a trick you should  use on  all  your  mobile gear ,  from  quads , bikes, boats  to  your  car  and truck.  The  newer SLA  and  gel  batteries  aren't  nearly  as prone to terminal corrosion,  but  greasing them   still  helps  keep   other   corrosive contaminants  like  salt  off them.
Good info Dave. I've come to that conclusion only recently, but at this time the ATV is at my home in Panama where I will be in January. So please wait and I will be sure to let everyone know what finally fixes it. I intend to take the crash bars, and plastic totally off and go through all the wires, as we have a lot of corrosion problems there. Also have a fuel problem that comes and goes, so I will be replacing all the gas and vent lines, cleaning the carb again and cleaning out the fuel tank and filter (which is where I think that problem stems. Thanks, Larry.
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Shadow soul60
      So I want to put LED headlights in my 99 Bayou 220. The stock headlights have some issue in the connector and they only work some of the time, so I want to replace them with LED light bars. I want to run them off the high beam switch. Which wire would this be?
      CARFAX https://www.carfax.com
