SID, know as seaisound, Our Motorcycle are directed from Japan
With the Complete International manufacturer Warranty
We ship only to the valid address
For security reasons, we are unable to alter the address or redirect the motorcycle after payment has been made
1 How much does it cost to deliver this to my location ?
Its 200usd to deliver to any local buyer. 300usd to International buyer
2 How long does the shipment takes ?
Delivery time to a Local buyers takes three days. seven days to International
3 What about the motorcycle registration documents ?
The registration documents would be ship along with the motorcycle
Contact us
info {at} seaisound . com
w w w . seaisound . com
Kawasaki Super sport Bikes
2015 Kawasaki Ninja H2R New $44,099
2015 Kawasaki Ninja H2 New $20,099
2015 Kawasaki Ninja ZX14R ABS 30th Anniversary New $10,099
2015 Kawasaki Ninja ZX-10R ABS 30th Anniversary New $9,099
2015 Kawasaki Ninja ZX-10R ABS New $9,099
2015 Kawasaki Ninja ZX-14R ABS New $8,800
2015 Kawasaki Ninja ZX-10R 30th Anniversary New $8,800
2015 Kawasaki Ninja ZX-10R New $8,800
2015 Kawasaki Ninja ZX-6R ABS 30th Anniversary New $7,700
2015 Kawasaki Ninja ZX-6R ABS New $7,500
2015 Kawasaki Ninja ZX-6R 30th Anniversary New $6,900
2015 Kawasaki Ninja ZX-6R New $6,700
Kawasaki Sport Bikes
2015 Kawasaki Ninja 1000 ABS New $6,900
2015 Kawasaki Z1000 ABS New $6,900
2015 Kawasaki Ninja 650 ABS New $4,500
2015 Kawasaki Ninja 650 New $4000
2015 Kawasaki Ninja 300 ABS New $2,500
2015 Kawasaki Ninja 300 SE New $2,300
2015 Kawasaki Ninja 300 New $2,200
Kawasaki Versys Bikes
2015 Kawasaki Versys 1000 LT New $7,799
2015 Kawasaki Versys 650 LT New $5,600
2015 Kawasaki Versys 650 ABS New $4,900
Kawasaki Touring Bikes
2015 Kawasaki Vulcan 1700 Voyager ABS New $14,099
2015 Kawasaki Vulcan 900 Classic LT New $4990
2015 Kawasaki Concours 14 ABS New $10,099
Kawasaki Cruisers Bikes
2015 Kawasaki Vulcan 1700 Vaquero ABS New $14,099
2015 Kawasaki Vulcan 900 Custom New $5,499
2015 Kawasaki Vulcan 900 Classic New $5,199
2015 Kawasaki Vulcan S ABS New $4,099
2015 Kawasaki Vulcan S New $3,999
Kawasaki Off Road Bikes
2015 Kawasaki KLX140L New $2,099
2015 Kawasaki KLX140 New $1,999
2015 Kawasaki KLX110L New $1,800
2015 Kawasaki KLX110 New $1,500
2015 Kawasaki KX450F New $5,099
2015 Kawasaki KX250F New $3,999
2015 Kawasaki KX100 New $2,200
2015 Kawasaki KX85 New $2,300
2015 Kawasaki KX65 New $2,199
    • By Hagbard
      Have a long story that I'll attempt to make brief. I picked up what was advertised as a 1987 LT230E with no cam or valve cover, harness dangling, no plastics, and all kinds of slop in every bushing and bearing, but hey, it was free and I love a challenge. Local guy had a couple 87 230E motors he was selling on craigslist, picked up one of those and a pisspounded DG RCM and header for $100. Went through the harness to start sorting things out and noticed a few key differences, like the stator connectors didn't mate up, one round and one square. Rubbed some of the grime off and found a VIN, Lo and behold - I have a 1990 LT160E, not a 1987 230E... By the grace of who knows what, the 230 just so happened to mount up directly to the 160 frame with no mods. Wasn't until I had broken the seal on starting to chase down the harness leads that I found out.
      As it stood, advertised as a 1987 230E
      After a bit of elbow grease and some eBay raiding.
      Made a new seat cover and found a set of plastics, New carrier bearings, and brakes all around.
      Pulled the steering and front suspension all apart and gave it some love with new bushings and tie rods
      Ordered a small fortune in NOS and China parts from eBay and RockyMountain and after a couple weeks of wrenching and soldering I have a nearly complete wheeler, in pretty decent shape. Cleaned up a Mikuni carb I had laying around and mounted it up with a cone filter and a Lowe's Racing™ intake boot, and fed it some gas, primed the carb and tugged on the started rope a few times, and sure enough it belkched out some soot and fired up, ran for a couple seconds and died. No sputter, just shut off. Checked for fuel startvation, vacuum in the tank, no problems there, plenty of gas in the carb. Suspected clogged air jets, so I pulled it out of the boot and gave it a shot of ether, and it did the same thing, fired up, ran strong for 2-3 seconds and shut off. Then suspected I f*%#ed up the wiring harness somewhere, and re-traced all the leads with my newly colored wiring diagram, thanks to my kiddo's Crayola marker collection, and everything looked good. Started to suspect the CDI, solenoid, or coil might be faulty and was flipping thru the manual when a buddy stopped by with a pair of boat seats for me to reupholster for him.
      He's a little bit of a savant with engines and electronics, and he got curious when I told him my predicament. Three minutes later he said "Hand me a pair of needlenose?" which he used to short the neutral switch to ground, and had me give it another tug. Fired up and ran great, no shutting off, so we deduced that the neutral switch must be at fault and after he left, I pulled it off to troubleshoot, and decided to flick the shifter a couple times with it off to see the little nubbin go around in a cricle. It didn't. I should mention at this point that I had previously changed the oil and while doing so, I took the opportunity to adjust the clutch without consulting the manual because I'm the dumbest guy I know. I did it according to the procedure I had learned for the LT185 I have, and figured the adjuster itself looked the same, they must be the same thing. I loosened the 10mm lock nut, and started turning the adjsuter screw clockwise waiting to encounter resistance, and then back it off 1/8 turn. I was really surprised when it kept turning and turning, but figured it must have been WAY out of adjustment, and went on with business. Figured I might need clutch plates at some point.
      Encountered this problem, and actually read the manual and the procedure is entirely different, and I realized that I had basically "adjusted" it into oblivion. I have since drained the oil and tried to re-adjust it twice, with no luck. Anyone have any idea what I can or should do to correct the issue, or am I missing something else entirely here? (chain is off and sprocket nut is loose, if that makes any difference.) Any insight or advice would be appreciated, thanks.
    • By jashadams
      Snapchat-1142015191.mp4
    • By Werewolf
    • By fishhouse3
    • By Old55
      Selling 1994 king quad.  $400.00 Complete quad. Engine is stuck.
      Located in Highland Mi.  248 514 0888  Old55
