I am assuming it is leaking from the overflow. Took the carb apart and it is clean inside. Put it back together and gas leaks out the host at the bottom. Tested to make sure the drain screw is not the problem when I had it off.
    • By Dumass
    • By Trent Finnessey
    • By DPDISXR4Ti
      Thanks...
    • By jhamrick75
