By jhamrick75
By cameronokeefe6
I have owned my 84 Honda 200m for years now and I am wanting to see what i could do to upgrade horsepower , speed , performance , power etc and do it safely and not cause future harm to the engine.
I was thinking on getting a 200x piston, will this work and give a good power increase ? I have heard people have done this in the past and it works great. and i was also thinking on a 200x cam , will the 200x cam fit in this engine and make a difference also does it require the upgrading of any other parts and will i have to run 91 octane instead of 87 ? has anybody run this setup before and got good results ?
I was also gonna go with a 200x carb but not sure if i have to buy an intake to hook it up or will it just bolt onto the 200m intake and fit fine ?
If anyone has any suggestions and advice on what i could do it would be greatly appreciated ! thanks in advance.
By Werewolf
Oil is getting in the air box from crankcase vent tube, I put the two hoses that go to the air box together then something started to smoke on the front of the engine. There is a filter? In the line I blew that out.
By mehim
Hi everyone.
By p5200
The studs in the sprocket hub are stripped out. The hub is probably walloed out also. Probably will have to have a new sprocket hub. I doubt I have the ability nor the tools needed for this job. Thanks for all suggestions/opinions!
20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4
