My 500 4x4 only works if shift lever is pushed forward, I understand that there is a switch in the shifter box that goes bad and am wondering if this could be the problem and is there any way to check it. Any suggestions would be appreciated.
    • By Tim Keiper
    • By carkivey3
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
    • By Sportsman500guy
