I just bought a Used Kodiak, that I will be using mainly for Ice fishing, and it ran fine at the guys house started right up and everything seemed fine.
I Got home and Hopped on to take it off the trailer, i Pressed the brake and hit the button and it turned over, fired up and then dies. (it starts cold so I was not concerned.)
When I hit the electric start again there was no noise or anything, Just the coolant indicator light illuminates when ever I hit the button. I cycled through the shifter (park, reverse neutral, and drive,.) and then hit the button again, with the same result.
I noticed the park light does not illuminate, but the reverse and Neutral do.
I tried starting it in Neutral, and again nothing it just illuminates the coolant light.
SO am I doing something wrong?
I finally put it in neutral and pushed it off the trailer, and started googling. I have not seen anything on this being a problem or even what it would indicate. Any help appreciated.
I went from full normal cranking to NO cranking, or clicking
The lights come on, and are not Dim. I will see if the voltage drops on the battery when i try and star it, when I get home, Friday or sat.
    • By Frank Angerano
    • By DPDISXR4Ti
      Thanks...
    • By mans
      Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
