I have a 1992 Kawasaki bayou 300 4x4. My initial problem it would not run unless full choke was on. So I tried cleaning carb and installed a rebuild kit and it ran bit better but not much. So I replaced carb and spark plug and regulator/rectifier. During testing of new carb the rectifier burned up so I replaced it. Now it fires up and idles fine but it backfires when you rev it up and then it will die as if the key was turned off. Now I know that the coil, cdi box, and stator are all connected. But I don't want to replace any unnecessary parts . This seems to be a ignition/electrical problem. I could really use some advice here as how to go about this. Thanks.
    • By Tim Keiper
    • By Dumass
    • By Trent Finnessey
    • By Kawasakibayounospark
