I replaced my wheel cylinders and things were good for very little bit.i have a good hard lever so im assuming my adjusters are working.what else could it be
drum brakes are very lax ... they need to be adjusted very very close to the hub, but even then, they are no where near as tight as disc ... and if wet you have virtually nothing ... use the engine to brake, down shift and then use brakes ...
I just put new shoes on and bled for around a half hour.i have alittle brake but its know wheres near right.i put the screw driver in self adjusters but I don't think they are working right.before I put the shoes on I had a hard lever so my master cylinder is good
i put the adjusters together wrong now i have a great hard lever.i have a lot of grease on my brakes so when i get some brake cleaner i should be good
    • By wheeliewayne
      my  2012 big bear 400 is hard shifting  can anyone help me
    • By mga
      My 2000 big bear 400 4x4 has 26x10x12 tires in front and 26x12x12 in the rears. Trying to find replacement tires those sizes are hard to find, or, when i do, they cost a lot more than i want to spend.
      But, there's a lot of 25" tires out there the same size, just 25" and not 26". If i got the 25" it should not make a difference....right?
    • By jmercer
      Wondering if 1997 klf400b has a decompression, I’m getting 90psi on gauge.
      Hello there
