2008 JIANSHE JS250 ATV-8 SPORT 5SPEED WITH REVERSE... where can I get parts for this??? Everything seems to be heavy duty quality... 525 chain Fast Ace gas charged adjustable shocks front n rear...Yamaha aluminium rims...it's a Yamaha Raptor copy with the exception of the front like (that looks similar to a Roketa front light)
    • By USRaider
      Hello all!
      Kept indoors but hasn't been run in 5 years.  We're not trying the engine until the gas is replaced, and the tires are reinflated. But the previous owner said their only issue was stalling when shifting to reverse without giving some throttle.
      I'm optimistic!  See y'all around!
    • By Michael76
      Just got a bayou 300 and put a new spark plug in it but it won't start.
    • By DonB
      Had fire start in muffler due to failing fuel pump &/or fuel pressure regulator.  Must I spend the $750+ for a new assembly from Arctic Cat?!?  Here's what I've tried so far.
      Replaced fuel pump & regulator - both from Quantum. PSI is 60 rather than the 42 the dealer advises it should be, so problem persists.  I've now twice replaced the Quantum regulator & discussed w/ Quantum. They advise that they don't have an alternative regulator that would bring PSI down to 42. I've tried several in-line, adjustable pressure regulators but they either didn't work or I couldn't get a constant pressure from them. FYI, I've only tried the adjustable regulators for Fuel Injected engines however, it seems that they require vacuum to function properly.  When I can temporarily get the PSI right, everything works great.  Anyone else ever dealt with this problem, and, if so how did you fix it?  Perhaps I should adapt the fuel system to include a gas tank return line?
      Any insights are greatly appreciated, Don
    • By Freddie
      My first quad and I have a problem. I have a Kawasaki Bayou 300 1997. When I start it. It will go on high idle for about ten seconds before it goes down to low idle. It does this even when I don't touch the throttle or the choke.
      Also, when I give it some throttle and let go. It will come back to fast idle for about ten seconds before it comes down to slow idle. Therefore I have to wait for it to slow up before I can shift. The throttle linkage drops right back to the stop on the carb buy the rpms stay up for a while. If you have any ideas what might be wrong please let me know. thank you Fred
    • By 86096
      I have a 1985 Suzuki LT230 GE quadrunner.  It has been stored in a shed for at least the last 15 years and has very low mileage.  Although the tires look and feel great... should I consider changing them since they are 38 years old?  I don't intend to ride to far or too fast but I don't want to have to walk out of the bush.  Any input would be welcome.
