:aargh:I have a 02 Kaw.Prairie 650 with around 2300mi. & 280hrs. on it.After alot of start&stop riding this weekend,the LED gauges stopped working.Still have neutral&reverse lights,but no odo,clock,speedometer,& fuel gauge.
What do you think went wrong & how can I fix?:mad:
    • By DPDISXR4Ti
      Thanks...
    • By Shadow soul60
      So I want to put LED headlights in my 99 Bayou 220. The stock headlights have some issue in the connector and they only work some of the time, so I want to replace them with LED light bars. I want to run them off the high beam switch. Which wire would this be?
    • By Dsluder
    • By marcosphoto
